the car run good has not lost power but it has blue smoke when u crank it and if u reve it up it smokes done compression test and it good
Sep 7, 2008 at 1:01 PM
LEGITIMATE007
CERTIFIED EXPERT
you could still have cacked valve oil seals causing the oil to drip a little inside the combustion chamber. Yes I would say its the valve seals if the smoke is blue ,if its black, then it has something to do with fuel.
