failed the 15 mph HC(PPM):
rpms=1630
CO2%=14.10
O2%=0.55
HC(PPM)=156 Avg. is 31 Max. is 142
after failing i purchased new plugs because the old ones were really rounded off..... so i was curious to see what trouble codes would show up on the diagnostics...it gave me a code 42 ( Vehicle Speed Sensor Signal ) trouble area says....
VEHICLE SPEED SENSOR CIRCUIT
VEHICLE SPEED SENSOR; ECU...???WHAT DO YOU RECOMMEND??? i have 3 days to fix the problem??
any suggestions?? oh i forgot to tell you the speedometer cable is broken..is that why, I didnt pass the smog test...point me in the right direction please..........:(
rpms=1630
CO2%=14.10
O2%=0.55
Oct 28, 2009 at 4:03 AM
