1991 Toyota Tercel Exhaust heat shields
1991 TOYOTA TERCEL
196,000 MILES • 4 CYL • 2WD • AUTOMATIC
AIONSOB
My car started making rattling noises. My mechanic said it was the heat shields. He said I had to replace the muffler. I thought that maybe the heat shields were in the muffler. Where are the heat shields on my car? I can't find a diagram of the exhaust system anywhere on the internet.
Thanks,
Frank
May 23, 2010 at 7:16 PM
CARADIODOC
  • 34,306 POSTS
Hi Frank. Welcome to the forum. The heat shields are tin plates that are bolted to the bottom of the car, above hot exhaust parts, or they can be welded to exhaust parts, typically the muffler and catalytic converter.
On the body, they tend to corrode around the mounting bolt holes. If you can get the nuts lose, adding a large washer solves the problem, otherwise, a lot of people just run additional self-tapping screws through them into the body, but you have to be aware there could be wiring harnesses above there that could get pierced, and you don't want sharp bolts sticking your feet.
Often the welded shields will break lose from the muffler and rattle. You do not have to replace the entire muffler just for that reason alone unless it is rusted through and leaking. Most shops can use a wire-feed welder to reattach the shield. Hose clamps will stop the rattle too if it is feasible to add one.
caradiodoc
May 23, 2010 at 7:43 PM
