1985 Toyota Tercel dead cyli.
1985 TOYOTA TERCEL
DEAN MOE
Engine Mechanical problem
1985 Toyota Tercel 4 cyl Four Wheel Drive Manual
The #1 cly is dead. when I pull the plug wire there is no affect. The cly has 180 lbs. of compression and the plug fires. This not fuel injected so I would think fuel is the same as the other clys. Any ideas would be appreciated.
Nov 12, 2008 at 1:13 PM
Hi, remove the valve cover to check the camshaft lobs, and valve train. If it only misses at idle check for vacuum leaks that would effect that cylinder.
Nov 25, 2008 at 3:27 PM
