1996 Toyota Tamaraw
1996 TOYOTA TAMARAW
RANDSKIE
1996 Toyota Tamaraw
my tamaraw fx has a loose compression. i want to know why and how do i fix the problem? please answer me asap... thank you
Jun 14, 2010 at 4:18 AM
MHPAUTOS
  • 31,937 POSTS
Hi there, low compression can be cause by faulty rings, burnt valves, blown head gasket, best you get a wet compression test done and report the wet and dry readings, a wet test is with about 2 teaspoons of oil in the cylinder, this seals up the rings and if comp is still low the problem will be in the gasket or valves, start here.
mark (mhpautos)
Jun 14, 2010 at 4:22 AM
AUBREYSAMSON
I have my car with a 5k engine repaired and replaced with a new ignition cables. It wont start and the battery gets weak already. What is the timing order of the ignition cables from the ignition cap? How would i connect its order since I forgot the order from the replaced cable? thank you so much......
Aug 6, 2012 at 4:06 AM
