The passenger window in my 2006 Pre-runner will not work. When the up/down activation switch on either door is activated the window will not go up or down and there is no indication (sound) that power is being applied to the window motor. The drivers side window motor works fine. Since both switches for the passenger window do not work I suspect the motor or a connection to it? Can you recommend a troubleshooting sequence and also where I can find some good illustrations for removing the door cover to access the motor? Appreciate any help. Thanks.
Bill
Bill
Aug 17, 2010 at 4:01 PM
