Hello -
Thanks for getting back with me.
I have attached the directions we have with pics..........hope this helps.
OUTER REAR VIEW MIRROR ASSY LH
COMPONENTS
Fig. 51: Identifying Outer Rear View Mirror Assy LH Components
Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
REPLACEMENT
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
2. REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH LH
3. REMOVE FRONT DOOR WINDOW REGULATOR HANDLE ASSY
4. REMOVE DOOR ASSIST GRIP COVER LH
5. REMOVE FRONT ARMREST BASE PANEL SUB-ASSY UPPER LH
6. REMOVE FRONT DOOR TRIM PANEL ASSY LH
7. REMOVE OUTER REAR VIEW MIRROR ASSY LH
a. Disconnect the outer rear view mirror connector (w/Power mirror).
b. Remove the 3 nuts.
c. Disengage the claw and remove the outer rear view mirror.
Fig. 52: Removing Outer Rear View Mirror Assy LH Nuts
8. REMOVE OUTER REAR VIEW MIRROR LH
. Apply protective tape to the outer circumference of the outer rear view mirror, as shown . See Fig. 53.
a. Using a screwdriver with its tip taped in protective tape, disengage the 2 claws.
b. Disengage the 2 claws and remove the outer rear view mirror.
Fig. 53: Removing Outer Rear View Mirror LH Claws
9. INSTALL OUTER REAR VIEW MIRROR LH
. Engage the 2 claws into the outer rear view mirror.
a. Engage the 2 claws and install the outer rear view mirror.
Fig. 54: Engaging Claws Into Outer Rear View Mirror
10. INSTALL OUTER REAR VIEW MIRROR ASSY LH
. Engage the claw and install the outer rear view mirror.
a. Tighten the 3 nuts.
Torque: 8.0 N.m (80 kgf.cm, 71 in.lbf)
b. Connect the outer rear view mirror connector (w/Power Mirror).
Fig. 55: Tightening Outer Rear View Mirror Assy LH Nuts
11. INSTALL FRONT DOOR TRIM PANEL ASSY LH
12. INSTALL FRONT ARMREST BASE PANEL SUB-ASSY UPPER LH
13. INSTALL DOOR ASSIST GRIP COVER LH
14. INSTALL FRONT DOOR WINDOW REGULATOR HANDLE ASSY
15. INSTALL FRONT DOOR LOWER FRAME BRACKET GARNISH LH
16. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
Torque: 3.9 N.m (40 kgf.cm, 35 in.lbf)
Feb 17, 2009 at 8:11 PM
