2004 Toyota Tacoma Not heat from heater what is wrong? how
2004 TOYOTA TACOMA
67,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEMORYEDIT
The heater blows cold air when the engine is idling. Plenty of hot air comes out when the engine is above an idle.
Jan 21, 2009 at 10:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect coolant level. If OK, inspect heater core hoses under hood. Ensure that both are warm to touch after engine is warm. If only one or neither are warm, indicates clogged/faulty heater core. If OK, inspect thermostat to ensure it is not sticking.
Post results and I will follow up.
Thanks for using 2CarPros.com!
Jan 21, 2009 at 11:07 PM
