Excessive Blow-by in 2.7 L
I have a 2004 Tacoma PreRunner 4x2 with a 2.7 L engine and 57k miles. It seems to lack power so I did a compression check which turned out OK, but when I did a leak down test, it had 50% leakage in each cylinder. I could hear air leaking from the oil fill hole in the valve cover. I couldn’t hear any leakage in the exhaust pipe or the intake manifold. When I take the oil fill cap off while the engine is running (hot or cold), air blows out. So much blows out that an oil mist sprays out and I can feel the air (and droplets of oil) from 2' above the hole. I have replaced the PCV valve and that didn’t help. The warranty expires on the power train soon.
Thanks in advance for any help!
Dec 19, 2008 at 10:37 AM
