Remove the door inside handle as follows:
A.Remove the screw and slide the handle forward.
B.Disconnect the handle from the control link and remove the handle.
Remove the door trim as follows:
A.Remove the 2 caps and 2 screws.
B.Using a screwdriver, remove the door trim upward then disconnect the connectors.
C.Using a screwdriver, pry the forward of armrest panel and remove the panel.
D.Remove the 2 screws and tweeter speaker.
E.Disconnect the connector, remove the 5 screws and speaker.
F.Disconnect the wire harness and remove the 2 grommets and service hole cover.
Jan 23, 2010 at 3:34 PM
