1999 Toyota Tacoma air flow sensor
1999 TOYOTA TACOMA
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUBINO51
My check engine light is on so I had a toyota repair shop get the codes and it read air mixture to lean - the repair guy said it is the air flow sensor and it would cost around $400!
Is this the correct diagnose and is it that expensive to replace?Could I do this myself?
Dec 21, 2009 at 12:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
a faulty mass air flow (MAF) sensor could cause this trouble code to appear. MAF sensors are normally pretty expensive, around $150 - $200 for the sensor. Replacement however is relatively simple and should only take around 30 minutes (about $35 labor charge). To me, 400 for this repair is a bit too much, you should be able to get a cheaper estimate elsewhere. If you want to do it yourself, it just takes removing a few bolts and disconnecting an electrical connector to replace it.
Dec 22, 2009 at 12:04 AM
