My 98 Tacoma shows a code that indicates a faulty coolant temp sensor. I bought one to replace it with but can't locate the sensor on the motor. Where is this sensor located? A picture of the location would be great.
I think the sensor for the temp gauge is next to the thermostat, and it's working ok.
Thank you very much- Chad
UPDATE- I located two sensors. One is up towards the front of the engine next to where it looks like the thermostat is hidden. The other one is on the very back of the motor right against the firewall.
Now my question is- which one of these sensors would cause the check engine light to come on? The trouble code indicates 'closed loop fuel control, insufficient coolant tamperature'
Jun 27, 2009 at 8:27 PM
