1996 Toyota Tacoma no fire fuel too much at times
1996 TOYOTA TACOMA
SCHWABS
Engine Mechanical problem
1996 Toyota Tacoma 6 cyl Four Wheel Drive Manual
truck getting too much fuel , it now is getting no fire as well
Mar 19, 2010 at 2:55 PM
No fire:
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Too much fuel
Could be the coolant temperature and oxygen sensors, leaking fuel injectors and fuel pressure regulator, and fuel return line clogged-
Mar 19, 2010 at 3:00 PM
