Electrical problem
1996 Toyota Tacoma 4 cyl Two Wheel Drive Automatic
I don't believe I am getting power to my fuel pump when I turn on the key, although I get power when I crank the engine. I am checking the blue wire at the fuel pump. Also when the connector is plugged in at the fuel tank I get continuity between the chassis and the blue wire but when I unplug the connector there is no continuity. I believe the relays are ok. My question is should I be getting power to the blue wire when I turn on the key and does this sound like the fuel pump is bad?
Oct 20, 2010 at 5:51 PM
