1997 Toyota T-100 Continues to blow a fuse
1997 TOYOTA T-100
YOURMOM
  • 4 POSTS
Electrical problem
1997 Toyota T-100 6 cyl Two Wheel Drive Automatic
My truck died while going down the road. Upon replacing a blown 15amp fuse, it will restart and be driveable with no problems for a short distance, but blows the fuse again. I don't have an owner's manual, so I can't tell exactly what the fuse goes to. Motor turns over with blown fuse but won't start. What is the problem?
Jan 22, 2009 at 4:35 PM
We need to know exactly what fuse is blowing-best thing I can tell you now is you have a short circuit that's causing the fuse to blow.
Jan 22, 2009 at 5:13 PM
KEVIN12881
  • 336 POSTS
fuse MAY be for fuel pump. does the cover not say what each and every fuse is for?
Jan 22, 2009 at 5:29 PM
YOURMOM
  • 4 POSTS
The cover was involved in an unfortunate accident and is no longer with us. I have no owners manual. I strongly suspect the fuel pump, as well. My real question is does the fuel pump really need to be replaced or is it just a relay switch, or some kind of short. This really depends on whether or not a fuel pump can "get weak" or do they just "go out"?
Jan 22, 2009 at 5:36 PM
Its gonna be tough with this one -look below is it one of these fuse
https://www.2carpros.com/forum/automotive_pictures/12900_fuse_block_4.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_fuse_block_2_1.jpg
Jan 22, 2009 at 5:46 PM
YOURMOM
  • 4 POSTS
Hard to read, but I couldn't find one at all on the i-net! The bottom diagram should represent the box under the hood and it would be the fuse labled EFI.
Jan 22, 2009 at 5:52 PM
I want you to remove the circuit opening relay-replace the EFI fuse-did it blow
https://www.2carpros.com/forum/automotive_pictures/12900_cor_2.jpg
Jan 22, 2009 at 5:58 PM
YOURMOM
  • 4 POSTS
Unfortunately, I had to leave the truck at work and the gate is locked up until early tomorrow morning. I can say that I did not mess with anything inside; I merely replaced the EFI fuse under the hood and it started right up, it went a 1/4 mile and blew again. Replaced it again, same result, but I'd made it back to work from lunch after the second time and thought it best to leave it there for now, lest I make the problem worse. I will certainly try your suggestion first thing tomorrow and post my results here. Thank you sooooo much!!!!!
Jan 22, 2009 at 6:11 PM
