Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
T-100
General
Fuse Test
1993 Toyota T-100 fuse removal
1993 TOYOTA T-100
134,000 MILES • 6 CYL • 4WD • MANUAL
DAD6963
MEMBER
1 POST
FOLLOW
how do you remove the 80A alt fuse in main engine compartment without breaking? mine seems to be stuck.
Mar 22, 2010 at 6:02 PM
USMCORDIE
MEMBER
Disconnect Battery.
Remove fuse and relay pannel on right front fender. (two bolts and its off)
Remove bottom cover of pannel.
Once you gain access, you will be able to remove the fuse link from the bottom of the pannel.
Remove two screws retaining wires to fuse link.
Mark wires. Installation is reverse of removal.
Apr 8, 2010 at 8:40 AM
