Hello -
Okay, we need to be sure so you are not searching for the wrong item. If the middle brake light is also on, and, brake lights are brighter than parking lights....then I would say your brake light switch is bad.
Check the switch at the brake pedal.....see if it is stuck in. You can also unplug it and see if they go out.
Once you check this and see it is bad, all you have to do is replace it.
Sep 8, 2009 at 8:38 PM
