misses and sputters
1987 TOYOTA SUPRA
ROBCRX
Engine Performance problem 6 cyl Two Wheel Drive Manual 80,000 miles
Hello, i have a 1987 Toyota supra with a 1989 supra 7mge engine. i just did the swap and it runs okay, it idles fine, but on acceleration it misses and sputters some between idle and 3000 rpms when i accelerate hard. and a little during normal acceleration. but after about 3000 rpms it pulls just fine. also after hard acceleration when i press the clutch in to begin deceleration the motor will die?? it does have an exhaust leak where manifold meets down pipe but i didn't figure that would make a difference. the original motor did the same thing only worse.
Well its not every time I press the clutch just sometimes and it doesn't loose all power if I keep on the gas it stays up and that problem must have worked itself out for the most part because it has only done that a couple times since last post the big problem now is the missing between idle and three thousand rpms.
any ideas.
Sep 19, 2009 at 11:54 PM
It sounds like you have a blocked catalytic converter. Here is a guide that will help you confirm and if so and guide on what you will be in for when changing the unit.
and
https://www.2carpros.com/articles/catalytic-converter-replacement
Cheers,
Sep 20, 2009 at 9:09 PM
ROBCRX
Man I love this site, you guys hit it on the money it was the cat and now it is all fixed, Where can I send some money? :)
Sep 22, 2009 at 5:16 PM
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Jul 10, 2017 at 4:06 PM
