1987 Toyota Supra OverHeating
1987 TOYOTA SUPRA
87SUPRA
Engine Cooling problem
1987 Toyota Supra 6 cyl Two Wheel Drive Automatic
Hello, I have an 87 supra that keeps over heaing. first i thought it was the thermostat so i replace that then the clutch fan then the radiator cap but the car keeps on over heating any suggestions?
Jan 7, 2009 at 4:46 PM
Check the radiator if its clogged-up, water pump working properly if okay could mean a blown headgasket, cracked head and block or an air lock in the system.
Best way to find out more why its overheating is to get it block and pressure tested.
Jan 7, 2009 at 5:13 PM
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
DO A COOLING SYSTEM PRESSURE CHECK OVERNIGHT
REMOVE THE #6 SPARK PLUG AND USING A BORESCOPE SEE IF YOU HAVE COOLANT RUNNING DOWN THE SIDE OF THE BORE
MOST LIKELY ITS THE #6 CYLINDER WHERE THE HEADGASKET BLOWS
NO BIGGIE JUST MAKE SURE YOU HAVE YOUR BLOCK , AND HEAD CHECKED
Jan 18, 2009 at 12:03 PM
