Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Supra
Ignition
Timing
1985 Toyota Supra timing
1985 TOYOTA SUPRA
18,600 MILES • 6 CYL • 2WD • MANUAL
ZRAIDER
MEMBER
FOLLOW
everytime i get the timing right at 10 degrees it cuts out. when the timing is off it doesn't cut out and runs fine in that regard
Nov 11, 2009 at 11:18 PM
CERTIFIED EXPERT
When you're checking timing are you jumpering Te-1 to E-1 in the check connector
Nov 12, 2009 at 1:18 AM
ZRAIDER
MEMBER
yeah..its weird when the timing is right (10 degrees) it cuts out at 2500 rpms. hen its way off it doesnt cut out..im thinking its the tps?
Nov 12, 2009 at 7:14 PM
