1999 Toyota Solara leakey stuff
1999 TOYOTA CAMRY SOLARA
REKOSAINT
  • 6 POSTS
1999 Toyota Solara 6 cyl 160000 miles
there is oil leaking I think from my enginge? Someone told me it needed a new gasket. How much would that cosst with labor?
Jul 12, 2009 at 7:25 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I do need to know where the leak is coming from as there is a number of places with varying costs involved.
Mark (mhpautos)
Jul 13, 2009 at 12:42 AM
REKOSAINT
  • 6 POSTS
Thank you for VERY promt reply. Seems that th leak is coming from where the front of the engine where is screwed together. It is the SLE V6 so there is like a fold there in the frnt and it seems a bit of oil is lining where that fold is.
Jul 13, 2009 at 1:01 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I will check a manual and see if i can come up with something for you.
Mark (mhpautos)
Jul 13, 2009 at 1:09 AM
REKOSAINT
  • 6 POSTS
Thanks alot My car knowledge on a scale of 1 to 10 is a 1 just to let you know so I really do appreciate it
Jul 13, 2009 at 1:18 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
Well we have a small problem, i am in Australia and i use an American data base for the work here, now i just looked up Solara and it has nothing on it, so may be its called something else? what i a m thinking is that the leak is coming from the sump or the timing case cover, these are at the point of the engine that you have described, i am at a bit of a loss, for more information.but i will keep looking,
Mark (mhpautos)
Jul 13, 2009 at 4:14 AM
REKOSAINT
  • 6 POSTS
Really apprecate your help a friend of mine who works on imports was telling me to start thre as well. The only other thing I know about the car is that sometimes overseas they call it "Camry Solara SLEV6" but you probably already now that so even if this is as far as you cen help I really appreciate you. Of course any other advice would be cool too!
Jul 13, 2009 at 10:53 AM
REKOSAINT
  • 6 POSTS
plus they say a picture is worth a thousand words maybe this help too
https://www.2carpros.com/forum/automotive_pictures/381384_IMG_2228_1.jpg
https://www.2carpros.com/forum/automotive_pictures/381384_IMG_2229_1.jpg
https://www.2carpros.com/forum/automotive_pictures/381384_IMG_2226_1.jpg
Jul 13, 2009 at 11:02 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
That pic is the rocker cover, they do leak often and may be the point of your problem, the front one is fairly easy to replace, but the inlet manifold must be removed to access the rear one, this will be a job for your mechanic,
mark (mhpautos)
Jul 13, 2009 at 6:16 PM
REKOSAINT
  • 6 POSTS
Thanks again for all of your help that matches with what I was hearing from alot of my frieds too. At least I know where to start now instead of showing up at the mechanic and bending over!
Jul 13, 2009 at 6:35 PM
