Mass air flow replacement instructions
2005 TOYOTA SIENNA
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOMN66
When you try to acelerate, the engine smothers. There are two other readings given to me by Advance Auto. Fuel system 1 - open loop. Fuel system 2 - open loop. The o-ring was bad on the MAF. I changed it, but no help. The floor in my garge is cold black from the sputtering exhaust, when you acelerate.
Jan 5, 2010 at 1:40 PM
Good morning,
I attached the testing for the MAF sensor. It is on the air intake between the air filter and the throttle.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
https://www.2carpros.com/articles/engine-black-smoke
Do you have any codes set in the system?
INSPECT MASS AIR FLOW METER
a. Output voltage inspection.
1. Apply battery voltage across terminals 1 (+B) and 2 (E2G).
2. Connect the positive (+) tester probe to terminal VG, and negative (-) tester probe to terminal E2G.
3. Blow air into the MAF meter, and check that the voltage output fluctuates.
b. Resistance inspection.
1. Using an ohmmeter, measure the resistance between terminals 4 (THA) and 5 (E2).
Feb 21, 2021 at 9:01 AM
SJCOULTER
I was just wondering on my specific vehicle model is the location of my MAF sensor?
Thank you
Feb 24, 2021 at 11:50 AM (Merged)
Good morning,
I attached the location of the sensor below for you.
REMOVE MAF METER
a. Disconnect the MAF meter connector.
b. Remove the 2 screws, MAF meter and O-ring.
HINT: At the time of installation use a new O-ring.
INSTALLATION
Installation is in the reverse order of removal.
OLDCATJR
I have a 0110 OB2 code and have replaced the MAF. some tell me the IAT and MAF are one and some say there is a separate IAT.
Feb 24, 2021 at 11:51 AM (Merged)
HMAC300
  • 48,601 POSTS
You do not have an IAT only a MAF which is part of an assembly/duct work. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
