2004 Toyota Sienna NOT COOLING
2004 TOYOTA SIENNA
REVRAV
Air Conditioning problem
2004 Toyota Sienna Front Wheel Drive Automatic 60000 miles
Hello
the fan is working fine but even after lowering the temp to min ac is not cooling blowing full blast hot air
couple of months ago i had knocked the car on the hwy into something either a dead animal or God knows what which dented the radiator. There was no leak nor an y other apparent damage so i did not get it checked. heating is working fine but something wrong with the AC
opinion needed.
thanks for your time
Apr 23, 2008 at 5:23 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
the first thing you will have to do is get the system pressures tested as you may have low refrigerant which will shut the system down.
Mark (mhpautos)
Apr 23, 2008 at 11:24 PM
