2002 Sienna idles very low
2002 TOYOTA SIENNA
GRAMOS2000
Got a 2002 Toyota Sienna, about 60000 miles. Once in a while, I would start my van and it would start off and idle very low and the engine would eventually stall. I'd try this over and over until it eventually starts off and idle normally. Any idea what this may be?
Mar 2, 2006 at 12:05 AM
First, check for vacuum leaks, if ok, check the mass air flow sensor. We have replaced many on that car. Also Scan your PCM for trouble codes.
Mar 10, 2006 at 6:01 PM
LOSTINMARS
  • 222 POSTS
i know this is old but justed wanted to comment.
the idle air control valve on these engines get stuck and cause this problem.
Nov 4, 2007 at 1:21 AM
Good call, I have seen that before also. Just forgot to mention it.
Nov 5, 2007 at 9:43 AM
