1998 Toyota sienna
1998 TOYOTA SIENNA
MINH99085
HI! I have 2 problems with this car. First, the seat belt light is on all the time. I have a multimeter, I would like to know where I start to troubleshoot. Second problem is tire low pressure light turned on and off frequently. I did reseted it according to owner's manual, but it's still going on. How can I check the system. Thank you so much!
Apr 26, 2006 at 9:29 PM
LOSONE
  • 1,616 POSTS
The switch is under the seat or in the base of the seat belt retractor. Un plug the wire and see if the light goes off.
The tire pressure issue is a dealer controlled item. They have a re-set computer that will either reset the sensors or tell which one is bad
May 1, 2006 at 11:44 AM
