Hi, I have a 2001 Toyota Rav4 2WD with 71K. My husband replaced the front brake pads 4 days ago. Today it started to make a rubbing noise only when he turns to the right. Otherwise, the vehicle sounds fine. He does not know alot about cars, but had done the brakes before on a truck. However, this time he did forget to bleed the brakes before he started so he did it at the end. He has a friend that told him he thought it sounds like the rotor needs turned. The only other work we have had done recently was at a shop, they drain and flushed: the coolant, power steering fluid and transmission fluid. Also they changed the differential fluid. Please let me know what you think it could be.
Apr 6, 2006 at 1:30 AM
