Typically a bad drive shaft will exhibit a vibration. Not often do driveshafts have to be replaced.
Does the clunk happen when you first put it in gear with you foot on the brake pedal? If so, I would suspect a bad u-joint on the driveshaft.
Where does the clunk seem to be coming from? Under you, in front in the engine compartment? behind you? Left side, right side?
Feb 7, 2007 at 5:22 AM
