Car shut off and would not restart
2009 TOYOTA RAV4
197,000 MILES • 1.2L • 4 CYL
NIKA RUKAJ
my car stopped I was able to turn it back on in couple of minutes I drove five miles to my mechanic. it turned off again the mechanic said it was the fuel pump. he changed the pump he went to turn it back on it will not start?
Jan 20, 2017 at 12:00 AM
SATURNTECH9
  • 30,869 POSTS
It sounds like the crankshaft angle sensor has gone out which will not allow the fuel pump to turn on here is a guide to help us and the location of the crankshaft angle sensor in the diagrams below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Jan 20, 2017 at 7:04 AM
SHANNON_PRIV
Thanks you for the post I had this issue and had to get a new crankshaft angle sensor cost me $112.00 all fixed I love this site.
Aug 20, 2019 at 12:17 PM
IRIS LATRONIC
turned it off and now it wont start.
Aug 20, 2019 at 12:17 PM (Merged)
HMAC300
  • 48,601 POSTS
try resetting security system. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
RUIZELIJAHR
Hello my name is Elijah.
About 5 months ago I was driving back with my car from Maryland to north carolina and the engine began to rattle.Eventually the engine stopped all together. At first I thought it was the oil because I hadn't changed it in awhile because I had been traveling consistently for the past 6 months. My insurance company took my car to firestone and they said that the engine was burnt out and I would need a new engine. Me and my father looked at it and saw that the air intake system was full of debris as well and we cleaned it out and tried to start the engine again and the air intake basically exploded. The top of it broke and we replace it and charged the battery but the car will still not turn. We think that I might need a new engine but were still not completely sure what is wrong. We don't have the money for any big repairs so I wanted to see if you had any advice on what we can do. Thank you for reading my question have a great day.
HMAC300
  • 48,601 POSTS
it's probably the engine is bad, probably low or no oil in it. you probably were using either or something like gas and if it turned over it backfired and blew the intake like you said. your cheapest option is to get a motor from a junk yard and use that.
SSUNNY316
2005 rav4 wont start, but does crank, however the strange part is that it only happens near the lake, it does not occur anywhere else.
Aug 20, 2019 at 12:18 PM (Merged)
KHLOW2008
  • 41,814 POSTS
That is strange. Maybe it likes the view at the lake? lol.
When it could not start, you need to check what is missing, fuel or ignition sparks.
If the vehicle is parked on an incline and the fuel level is low, the fuel pump might not be able to draw the fuel.
SSUNNY316
chicago is pretty flat, however it does work when i step on the accelerate and then start it, but only works after a couple of tries and i dont want to mess up the starter.
KHLOW2008
  • 41,814 POSTS
Is the Check Engine Light indicating?
If using the accelerator works, it could be a fault with the Throttle Position Sensor. Other than that the accelerator is not going to affect anything.
Have the fuel pressure checked. Difficult starting are quite often due to low fuel pressure and more cranking than normal is required to prime the fuel sysyem pressure.
KYZON45
Computer problem
2003 Toyota Rav4 4 cyl Four Wheel Drive Automatic
please help me troubeshoot my car toyota RAV4 2003 no sign of check engine but i cannot start the car.
BMRFIXIT
  • 19,053 POSTS
With key ON you should have check engine light on
and if so check for fuel pressure
check for spark
check fuses
HEURISTIC.CHICK
My Rav4's battery finally gave out on me, so I changed it. However, now that I've done that, though it starts up fine, the radio doesn't work, the brake lights don't work, the keyless entry only sort of works (it yells at me when I try to lock it when a door is open, and it makes the little "unlock successful" beeps, but it doesn't respond at all to the "lock" button) and the car won't shift into gear. I also have no horn and no turn signals.
I can successfull get it into gear and drive it by using the override button, but obviously, I'll just be driving it to the repair shop (using hand signals!) if I can't figure out what the deal is.
I've checked all of the fuses and they seem to be fine, but will allow that I might have missed something.
What is wrong with my car?
Thanks!
Your brake light circuit powers the shift interlock system computer get it checked out this will prevent you from shifting into gears.
IORDACHE
This car was wrecked and has the front airbags deployed.
All the harness look O.K. , half of the fuses do not have power .
Got power on the cluster but when turn the key to start doesn’t do anything.
Does this car power switch to cut the power off in case of the accident?; and where is locate ?
Than you !
Some have a switch to shut off the fuel pump, but the engine would still crank. I don't know how hard it was hit, but you need to start at the power source, the battery. Check and make sure the ground to the engine block is clean, tight, and not damaged. Also, follow the positive cable from the battery to the power distribution areas to make sure nothing was damaged there.
Let me know what you find.
Have you had a chance to check it?
REXLINT
Clean battery contacts, recent new starter. Turn key to start, the panel annunciator lights don't dim, starter relay does not click - nada. Leave key ON for random time (3 to 10 minutes) and it will start normally. What's wrong?
ROMYSPEC
  • 38 POSTS
locate and check the starter relay,also check starter cercuit for slack connections.
Have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should have 12+Volts. If you do, have the starter rechecked. Chances are (even though it is new) it is bad. If there is no power, look for the starter relay (under the hood in relay block). Switch it with another that has the same part number to see if that changes things. If it still doesn't, check for power where the relay plugs in in the start position. If there is no power, then you need to have the ignition switch checked.
MZEE
Engine has failed to start, there is no spark to start engine.I have checked wiring is okay
CARADIODOC
  • 34,306 POSTS
Have you checked for fuel pressure? What about reading the diagnostic fault codes?
Wiring problems only cover about half of the list of possible causes. Since you're checking for spark, I assume "failed to start" doesn't refer to the starter failing to crank the engine. The most common suspects are the crankshaft position sensor and the camshaft position sensor. The fault codes will indicate which circuit or system needs further diagnosis.
CHABONAL
Electrical problem
2004 Toyota Rav4 Four Wheel Drive Automatic
alternator got busted couple of weeks ago.. they had it fixed,, and now it wont start again and they said its the battery... is it because of what happened w/ the alternator or they just didnt fixed it well that it damages the battery..? tnx
The alternator could be defective and not reconditioning the battery or the battery is sulfated not taking the charge
BIGALBIE
car was working fine i changed ground cable and terminals now the car just turn over but doesnt start
LOSTINMARS
  • 222 POSTS
damn dude you didn't even bother looking around here 1st....don't worry i'll do it for you.
https://www.2carpros.com/forum/2003-toyota-rav4-replaced-battery-and-now-wont-start-vt91390.html
KMIG
  • 11 POSTS
it has spark-fuel-and timing belt turns.i code tested found a code po340 camshaft position sensor malfunction did oms test on sensor it seemed ok. opion if you have one thanks alot
GFIMOTORCARS
  • 673 POSTS
With this code and a crank no start condition you are more than likely looking at a failed camshaft position sensor. This is a fairly inexpensive part ($80-100). Checking resistance (ohms) of the sensor your range should be between the following and not at either extreme, as this is an indication of coming failure. If it is cold where you live
-10-50deg F, then your range is 985-1600ohms
50-100deg F, then your range is 1265-1895ohms.
Keep in mind you can have a failed component that tests good ohms.
