Hi Destra,
Thank you for the donation.
Sorry to say I am not able to locate any information for the code mentioned in the DTC list of our database.
Apart from the trouble code, what are the symptoms associated with it?
What scanner did you use?
I believe vehicle should be under warranty as it is a 2007 model, did you send it back to the dealer?
Since vehicle is a 2007 models, some trouble codes are not availble to non Toyota Service and it might not be easy to get the required information.
Jul 30, 2009 at 2:01 PM
