the car started to slip gears then check transmisson fluid. I had add to a quart of fluid but car still slip between first and second gear ocassionally. Sept 2008 had ecm reflashed. Does the car ecm need to be reset or can it be a bigger problem? Should the ecm be replaced?
Sep 20, 2009 at 8:03 PM
