Hi there,
Thank you for the donation,
This i feel is not so, the ECU is just a control unit sending and receiving information on engine & transmission parameters, the solenoid is just a valve, and if it fails normally there is a drive problem,depending on which one it is, but i find it hard to believe that it has destroyed the transmission, is this report from a general mechanic or a qualified transmission repairer? i would like to see the report, but one really needs to be able to view the problem first hand, otherwise i am only relying on an honest report from the tech doing the job, i would be getting a second opinion from a transmission tech, and comparing the reports, post your findings here i would be interested in knowing what they say.
mark (mhpautos)
Dec 18, 2009 at 4:53 PM
