2000 Toyota Rav4 anti freeze leak
2000 TOYOTA RAV4
145,000 MILES • 4 CYL • 2WD • AUTOMATIC
KTM513
  • 4 POSTS
car is leaking anti freeze ,lft side of engine,,looks like behind the thermo stat , doesnt look like the inlet tube,,is there a freeze plug ? or could it be the water pump? i cant see up in there
Apr 10, 2010 at 12:14 PM
KHLOW2008
  • 41,814 POSTS
Hi ktm513, Thank you for the donation. Here is a daigram of the thermostat housing and water pump. If leakages are around the area, the most likey source would be the water pump and the O rings for the coolant by-pass pipe. Without a visual, it is not possible to determine waht could be the cause. Get a strong light and a small mirror to try to located the source.
https://www.2carpros.com/forum/automotive_pictures/192750_WaterPump00RAV4Fig27_1.jpg
Apr 10, 2010 at 11:20 PM
