1998 Toyota Rav4 tranny won't engage in 5th gear
1998 TOYOTA RAV4
118,000 MILES • 4 CYL • 4WD • MANUAL
SHADETREE33TECH
Our 98 RAV4 recentyly quit shifting into 5th gear. We were travelling at about 40mph when it popped out of gear. Now it won't engage in 5th gear.
The garage I took it to said it needed a whole new transmission. Over $2000!
My friend said it was more likely a linkage adjustment.
Can you please advise me on what steps I can take to determine which way to go. Thanks in advance.
Jul 14, 2008 at 5:08 PM
KHLOW2008
  • 41,814 POSTS
Hi shadetree33tech,
The synchromesh rings and hub are worn. Best you can pray for is that there is a loose locknut inside which will solve the problem if it is retightened.
You don't need a new trans, just replacing the 5th gears set will do. Get a second opinion from someone who can do repairs on trans.
Jul 15, 2008 at 11:35 AM
