1997 Toyota Rav4 High revs
1997 TOYOTA RAV4
115,000 MILES • 4 CYL • 4WD • MANUAL
ROYWILLSONUK
I have a toyota RAV4 P reg, on idling the revs are very high over 2000rpm. It has now started to cut out after high revs and then slowly dropping until it cuts off especially when in traffic. Seems worse after Braking, when clutch is down. Thought might be the accelerator cable but now not so sure. Any help would be much appreciated.
May 21, 2010 at 8:49 AM
Clean out the idle air control valve and test the throttle position sensor and the airflow meter
May 21, 2010 at 7:17 PM
