Electrical problem
1996 Toyota Rav4 4 cyl Four Wheel Drive Automatic
The car wouldn't start. I noticed excessive corrosion on the battery terminals. I cleaned the terminals and connectors as well as I could. The car ran for two more days then quit again. There is major corrosion on the connectors, and the corrosion goes all the way up the wire into the insulated portion of the wire. There is also a small fuse box on the positive side of the wire that is also corroded. What is this fuse box for, and how much wiring am I going to have to replace?
Sep 23, 2009 at 5:13 PM
