no spark
1995 TOYOTA PREVIA
RHOLLAND
  • 5 POSTS
no spark at the plugs coil has power distributor is okay? Fuses are ok, constant power to coil positive but not out of coil wire What's going on?
Jan 1, 2007 at 3:47 PM
Check the EFI fuse, Ignition fuse and the EFI main relay then comeback for more help. Its right on the bottom of the J/B cover identifying the relays and fuses.
Coil has power do you mean the positive terminal of the coil-disconnect the coil wire at the distributor, have someone crank it over, ground it and check for spark.
Find the check connector under the driver seat put a test lite on the battery terminal tell me if you have power there.
At J/B- when you turn key On, the EFI relay should click-do you have this?
Also stick the test lite at the EFI fuse both contact- test lite should lit.
Jan 2, 2007 at 1:03 AM
RHOLLAND
  • 5 POSTS
replaced the efi relay and it clicks now , but it stopped clicking after trying to start about ten times also it had the wrong (bad) computer, replaced it now it runs great! thanks for your help
Jan 11, 2007 at 9:39 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
Jan 12, 2007 at 4:48 PM
P DASH
my toyota previa all wheel drive with a 2tz-fze super charged engine has no spark in cyl 1 and 2 cap rotor and plugs are brand new
Nov 20, 2018 at 11:06 AM (Merged)
Check nad test the Crankshaft Position Sensor (2TZ-FZE)On left front of engine.
