Squeak like loose belt is heard while idling. Belts are fine, though. After a short drive of 5 miles the temp. gauge reads most the way to red, and water in plastic reserve is boiling. Park for an hour, no coolant left in plastic reserve, but no apparent leak visible under vehicle. If I force water into reserve while running engine, squeaking noise stops temporarily. Replaced thermostat, water pump, removed and routed radiator. What else to do?
Jan 12, 2010 at 2:19 AM
