1994 Toyota Previa engine overheating
1994 TOYOTA PREVIA
19,000 MILES • 4 CYL • 2WD • AUTOMATIC
RTUCKER1964
My 94 Previa is overheating. I changed the thermostat but problem still exists. I don't see any liquid coming out of weep hole in water pump. I am pretty sure temp guage is operating correctly. Once engine heats up temp rises and fluid returning to resevior is way hot and vents out through overflow tube. I was told there may be air in the system following the thermostat change. Is that possible or do I need to be looking elsewhere?
Dec 15, 2009 at 10:27 PM
Check those hoses on the overflow bottle for blockage if okay bleed the system
Dec 15, 2009 at 10:37 PM
