My truck ran great, but I needed to do some cleanup on it. I changed the oil, plugs, and filters. I did the coolant also. I drainded the antifreeze, refilled with water, ran the motor for a heat up, let it cool, and refilled with antifreeze. I ran the motor till warm with the rad cap off to get the air out, and refilled what was needed.
I took it around the block, the temp gauge ran almost all the way up within a couple of minutes, the heater was blowing cool air. I got back quick, the rad was hot, hot. I let it cool. I see no leaks, but as it is cooling, air, burping into the resivour.
I can't believe it is a head gasket, water pump, or thermostat, the truck ran great an hour before.
And the heater always worked also, but it is not blowing hot air now. Please help me out.
Oct 13, 2006 at 5:18 AM
