I own a 1992 Toyota 4x4 pickup with a 3.0 v6. It has a problem with a recently rebuilt motor that has around 25,000 mi. on the new motor. It started having the same problem that it had before the rebuild. The problem is that it overheats whenever it's driven over 65 mph. + or - 10mph depending on wind direction, air temp. and AC use. I think it's blowing coolant out the overflow bottle. I've replaced the radiator, Flan clutch [twice], and can't find any leaks in the hoses or heater core. It doesn't seem to use any coolant when driven under 55mph. What else should I do and check. Thank You... Kit
Nov 12, 2007 at 5:03 PM
