shifting rpm goes up
TOYOTA PICKUP
BTTF11985
  • 23 POSTS
Hi I have a 85 toyota pick up 22rec 131,000 miles I have noticed when I shift from 2nd to 3rd the rpm stays at 3000 it doesnt go down when I push the clutch in but in 1st ans 2nd it doesnt do this. Also I have low compression in the 2nd cyl only 75 and all other 3 cyl are fine on compression 176 DRY TEST The spark plugs have oil deposies on them so they are fouled out and only when I first start the truck and drive till I get into 3rd the smoke stops the smoke is bluish and there is like burnt oil that spatters out the muffler not to much. Thank you for your time reading this!!!
Oct 24, 2007 at 6:46 PM
At the no.2 do a wet on it if it doesn't rise-you got a valve problem, also the blue smoke is caused by worn valve seals/plus oil is leaking thru and coating the plugs causing it to fouled. Its time for a Valve Job.
Oct 25, 2007 at 2:22 AM
