hi...i have a toyota truck..2wd..1992...170+ miles.. reg cab..stick..what the prob..is it wont start..i check for 12 volts and not geting any at the fuel injectors or cold sensor..but if i put a 12 volt generator at the cold start injector the one on top of the throttle body...it would run...but then die when i could not keep up with the timing...!!! i replaced the O2 sensor and the fuel pump three times and the battery..now some one on justanswers.com said it might be the electronic starter relay and gave a schmatic and it shows the injectors coming off the relay..but is that true and could it be something else before i pay them...can you help...??? thanks sean
Apr 18, 2006 at 10:47 PM
