I have a 94 toyota pick up with 260,000 miles on it. it is a 4 cylinder.Okay...so I got an estimate of 2300$ I was told my timing chain wore a hole in the timing cover, my radiator had a crack in it, the water pump was leaking and I had a blown head gasket. the guy told me the timing chain scenarioo probably caused coolant to leave the radiator which made it hot and it cracked/split, thus the rest of the car got hot and blew the had gasket. Is it possible taht i was driving around and there were NO problems what soever and then all of a sudden all this stuff?
Can someone PLEASE explain to me how all these things work together in conjunction to effect the other components that have failed. I want to make a judgement about whether my truck is worth saving or not. Is what the mechanic told me probably accurate?
Sep 15, 2007 at 5:21 PM
