Fuel pump
1987 TOYOTA PICKUP
FUDD
I turned the truck off and when I went to start it, it would turn over but no start. Replaces the fuel pump but when I turn the key on the pump will not run. I jumped the wires to the pump and it pumps like crazy.
22re 120,000 miles.
If this has a fuel pump solenoid I cannot find it anywhere.
Oct 6, 2007 at 11:27 AM
Check the EFI fuse, EFI relay, circuit opening relay these go out all the time. Here is a guide and the location below so you can test for the issue:
Cheers
Oct 11, 2007 at 11:02 PM
DEARHUNT05
  • 4 POSTS
Yep, great guide. I tested the relay and it was bad truck started right up with the new relay. I love this site.
Mar 15, 2008 at 11:08 AM
FALCON4LIFE
I have a 4x4 pickup with a V6 3.0 engine. First I can not find the fuel pump relay. Where is it? It is not under the hood in the fuse box.
Also, I took of the bed to get to the tank, but how do I get the access plate off? It looks like it has screws or bolts or something, but they are so rusted that they just look like little round heads. Does the access plate just twist off?
Thanks for any help you can give me!
Aug 2, 2018 at 12:05 PM (Merged)
The COR powers the fuel pump and MAF sensor grounds it to complete the fuel pump circuit.
EFI circuit opening relay behind right kick panel, above the ECU.
Why are you chasing it-is it no power to the fuel pump connector. Do you hear the pump come on when key at on position.
About the access plate you have to go through it to get to the pump?
FALCON4LIFE
No, I do not hear the fuel pump with the key on, so I checked the power at the plug at the tank with the key on, and it shows no power.
Thanks for your help I found the circuit opening relay. How is the best way to check it?
Thanks again.
The COR powers the fuel pump and MAF sensor grounds it to complete the fuel pump circuit. Could be the relay, what about the power that goes to it from key is it there at the relay-if its there then it is the relay.
