E-brake handle pulled out cant get it back in
TOYOTA PICKUP
THE_ROOKIE87
I just got an 1987 yota pickup with the 22R in it and the damn thing is not in too good of shape but here my prob... i was trying to get the e-brake set and the damn handle just pulled all of the way out. it didnt even turn like it says on the handle. well the knob turned but i guess no the rod connected to it... but if u could help me try and get it backin that wpuld be great... thanx
Mar 5, 2006 at 8:02 AM
FISHERMAN
  • 937 POSTS
check if the handle has a roll pin broken or its just a set-screw loose..
now use a pair of pliers, pull the handle and with the pliers turn the shaft...
Mar 6, 2006 at 2:07 PM
THE_ROOKIE87
thats not the prob... the handle and the shaft are now sitting in the passanger seat with nothing else attached to it.. i need to know how to get it back in (attached) so that i can pass an inspection... would it just be best to go to a junk yard and get a new (used) one?
Mar 6, 2006 at 11:05 PM
FISHERMAN
  • 937 POSTS
yes, that`s an easy fix..
you can find it there..
Mar 7, 2006 at 8:47 AM
THE_ROOKIE87
thank you for the help.... i went to the jnuk yard and got the assembly and installed it...... now i just have to go get it inspected... hope it passes
Mar 7, 2006 at 9:03 AM
