cable going to the air intake
TOYOTA PICKUP
REBELRIDER
1993 toyota 4x4 V6 a cable going to the air intake when disconnected the truck will start, only runs for about 5 sec. when pluged back will not start at all. I have a repair book and it says nothing about the cable. I have followed the cable from plug in to a box
and can not see were it goes from there. can you help me
Mar 19, 2007 at 6:58 AM
[quote:f4cfe6c648="rebelrider"]1993 toyota 4x4 V6 a cable going to the air intake when disconnected the truck will start, only runs for about 5 sec. when pluged back will not start at all. I have a repair book and it says nothing about the cable. I have followed the cable from plug in to a box
and can not see were it goes from there. can you help me[/quote:f4cfe6c648]
3.0L engine
Your description sounds like the mass airflow meter-in this box do you see an airfilter lookiing
Cable-is it steel stranded looking wire or a connector that has atleast 7 wires on it.
Also is this box close to the alternator
Mar 19, 2007 at 8:48 AM
REBELRIDER
It is a plug that has about 7 wires running to it
Mar 19, 2007 at 4:13 PM
Open it up and inspect and test if not in specs by the book/manual and also cleaning it up
Replace it
Mar 20, 2007 at 4:15 AM
REBELRIDER
thanks for help. Cleaned contacts on cable and truck is up and running. Big help
Mar 21, 2007 at 5:41 AM
Glad to hear the Toy is up and running
Good Luck
Mar 21, 2007 at 9:03 PM
