92 Toyota Pickup - Clutch or Transmission
1992 TOYOTA PICKUP
LAGREEN
My son just brought home a 92 4x4 pickup, 200,000 miles. Help!
Can't get into gear while the engine is running - lots of effort and/or grinding. When engine is off, can get into gear no problem.
Repair shop just said 'replace the transmission' - how can I tell if it's the trans or the clutch?
Nov 13, 2007 at 9:42 PM
Bleed the clutch slave/servo, adjust the free play and pedal height-this don't cut it-time for a new clutch assembly that means clutch disc,pressure plate,release bearing and pilot bearing
Nov 14, 2007 at 2:02 AM
