Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Pickup
Electrical
Alternator
Replace/Remove
78 Toyota Pickup alternator replacement question
1978 TOYOTA PICKUP
JPYLE721
MEMBER
FOLLOW
I need to replace my alternator, should I replace the voltage regulator at the same time? Both are original equipment 360,000 miles.
Oct 22, 2007 at 3:54 PM
CERTIFIED EXPERT
What's wrong with your alternator-did you confirmed its no longer reconditioning the battery. Maybe the battery is not taking the charge. Get back.
Oct 26, 2007 at 3:11 PM
JPYLE721
MEMBER
I installed a rebuilt alternator to see if the .72amp battery draw would go away it did not. Could it be the voltage regulator?
Nov 13, 2007 at 3:36 PM
CERTIFIED EXPERT
Remove all the wires from behind the alternator and isolate it from ground if that draw is still there, your problem is coming from somewhere else.
Nov 13, 2007 at 4:22 PM
