2006 Toyota Pickup engine rattle generaly when cold
2006 TOYOTA PICKUP
KOOGS
Electrical problem
2006 Toyota Pickup 4 cyl Four Wheel Drive Automatic
i have just purchased a toyota hilux sr5 2006 model twin cab ute it has developed a rattle in the top end when cold when driving off it is not as noticable once warmed up. also a slight hunting when idling.have taken it to a reputable diesel mechanic and as i believe it could be a injector malfunction. i also had a toyota technician do a diagnostic check through the on board computer and found that all the paramerters where within specs. it will also create a rattle intermitently whilst idling.it is more noticable whilst taking off under load even slight load.it is 3ltr turbo intercooled engine engine number 1kd700873 vin no mrofzz29g601534210
May 5, 2010 at 4:31 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
I would get the comps check and have the injectors serviced, i feel it is a faulty injector, start here.
mark (mhpautos)
May 5, 2010 at 6:45 AM
