2004 Toyota Pickup TIMING CHAIN
2004 TOYOTA PICKUP
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARRY WALTER
should I go ahead and change timing belt or will I hasve some sort of warning before trouble happens ie noise etc
thanks
Nov 10, 2008 at 7:10 AM
Replace the timing belt now-don't wait for any type of noise could cost you a major repair later
Nov 10, 2008 at 7:17 AM
MASTERTECHTIM
  • 4,750 POSTS
i would suggest replacing it. a lot of times there will be no warning at all, it will just snap and sometimes you will get a warning growl if a pulley or tensioner is starting to fail. if you have 90k then your running on borrowed time already. some vehicles are known for certain mileage belt failure. some will break right at 60k when the interval is suggested and some will last alot longer 90k plus but its a gamble.
Nov 10, 2008 at 7:19 AM
